Post Configurator and Rotate UD
I have a new post created with Post Configurator.
The Machine is a Head / Head C / B. I started with a Fanuc Control.
Peliminary testing looked good. I posted a file with multiple operations and received a warning Rotary crossing limit and Previous rotary axis solution degenerated.
I normally set Rotate to Reference Only. I need a windup and want to start at C-180. It starts at C180.
If I un-check Reference only it will output a C-180 and then position the first move to C180.
I'm guessing PC is not setting previous out angle to the Rotate C-180?
Has anyone come up against this yet?
Thanks in advance
Doug
