Post processor
Builder
Builder
How can we output nc file of selection of multiple operation and each nc file will be separated as operation
Re: Post processor
Hi @Vora
import the custom command pb_tape_utils.tcl from the ~\POSTBUILD\pblib\custom_command directory. It has instructions in the text.
Paul
Re: Post processor
Builder
Builder
Re: Post processor
Builder
Builder
I found that file but i cant understand how to start with it
Re: Post processor
@Vora
Here is a video of how to use the custome command.
Paul
(view in My Videos)
Re: Post processor
Builder
Builder
As you say by video guideline i rich only save my .pui file into the postbuider
But,
My problem is still not complete
output NC file from selected operation is merged as a name of my 1st operation
Please see this photos and you know what is my actually problem
Re: Post processor
Hi @Vora
That's strange. I just tested and it works ok for me. I have also attached a sample post for you to test. If you like I can check your post of you.
Paul
Re: Post processor
Builder
Builder
Thanx
Let me try your postprocessors
And i will post my postpro. In tomorrow morning
Re: Post processor
Builder
Builder
Please check my post tell me hows different post from your post
Re: Post processor
Hi @Vora
You had the custom command set in the program start sequence. It has to be in the Operation start sequence --> Start of Path. I fixed your post and tested. It works fine. I have attached the fixed version for you to try.
Paul
