Postprocess each operation from a selected group independently
If anyone needs, I have created a NX CAM application that postprocess each operation from a selected group independently.
digitaltwin_postprocess.pngTo be able to use it, you have to copy the .dlx file to UGII folder or you may define $NX_CUSTOM_TOOL_BARS and place the .dlx folder in $NX_CUSTOM_TOOL_BARS\application
Use it at your own risk.
Edi
6 REPLIES 6
Re: Postprocess each operation from a selected group independently
Thanks for sharing your program. You might get more feedback if you posted it in the customization and programing forum.
Mark Rief
Retired Siemens
Is there any way to make this application work in NX 4.0 ?
The original creator would have to re-compile & link it for NX4
I believe NX4 had journaling - this could be done with a journal.
Any reason you can't upgrade to a more current X release?
It has been a while since I dealt with NX4, but see if there is a folder
(install location)\UGOPEN\SampleNXOpenApplications\.NET\CAM
If there is, try to find a .VB that loops thru all operations.
This could be adapted to post each operation, rather than doing whatever it does.
I did not tried. Is there any error you get?
*Eduard Oprea*
+40 723 610 259
eduard.oprea@digitaltwin.ro
linkedin.com/in/eduardoprea
www.digitaltwin.ro
Bulevardul Dacia nr 30,
București 010403,
România
Ken_A we have NX 10 but the interface is just too complex compared to NX 4. We prefer NX 4 because the simpler interface makes our work much quicker.
There's a folder "(install location)\UGOPEN\SampleNXOpenApplications\.NET\" but no "CAM" subfolder in it (see attached screenshot).
Edi looks like .cs file are not supported in NX4 Journal  (see attached screenshot). I can load ".vb" ".cxx" ".cpp" and ".java" files.
Builder
Builder
Hello, thank you for application. Questions, is possible add option for postprocess only selected operations?
