Postprocessor Privacy
Builder
Builder
Can we set privacy for postprocessor that nobody can use our postprocessor like any password or any other tool and nobody can share it ???
Re: Postprocessor Privacy
for this is useful postconfigurator (what I am not familiar with)
In postbuilder you can check some variables and make some code to achieve it
Builder
Builder
But how??
Hi @Vora
This is just some Ideas, I have tried this.
If you want to lock the post that only can run on specific username AND hostname ONLY, just make condition in tcl file.
except condition make it error mesage: " Please call Vora to fix this problem" Smiley Happy.
If you want it more advance protection, make condition locking with specific mac address.
May be both of them, good to try.
Maryadi
PT.Mitra Makmur Teknologi
www.m2teknologi.com
Builder
Builder
I know it
But how to start from initially?
Hi @Vora
Example:
Please delete the pui file to secure from editing, let them only .tcl and .def left , then open yourpost.tcl, search "proc MOM_linear_move { } {"
It will shown as below:
   ABORT_EVENT_CHECK
   HANDLE_FIRST_LINEAR_MOVE
   PB_CMD_suppress_linear_block_plane_code
   MOM_do_template linear_move
Just make changes to give Condition as shown below:
global mom_logname
if {[string match "LOGIN_NAME" $mom_logname]} {
ABORT_EVENT_CHECK
} else {
MOM_output_literal "ERRORR.. Please Call Vora to fix this problem"
 Then save the file.
Try to test the post...
You can do this on circular move or any other proc. even you can stop at the begining of process.
Just have a try. This is just an Idea.
Maryadi
www.m2teknologi.com
Hi @Vora
What I mean is try to post with other login name.
Then you will see your error message, when you postprocess the operation.
Maryadi
www.m2teknologi.com
You can buy a license from Siemens to encrypt your post-processors and password protect them.
On the other hand, if you don't send the PP out into the public, there is no need to protect them.
