Postprocessor for Fanuc 6m
Can I get it from someone, or build a new one or edit/modify an existing one ?
I need a Postprocessor for Fanuc 6M (I am using NX11)
Actually I need it for a ProtoTRAK SMX control but they say it is similar to Fanuc 6M
How can I build my own Postprocessor using only the G codes and M codes accepted by my CNC Control ?
14 REPLIES 14
Re: Postprocessor for Fanuc 6m
I suggest you can at least start with one of teh OOTB (Out Of the Box) installed posts comming with NX.
You will find all of them in the folder of the installed machines:
..\mach\resource\library\machine\installed_machines\...\postprocessor
Thomas Schulz
Siemens PLM
Teamcenter 11 / NX 11 - where is the Post Processor Builder ?
I can not find it !
Windows Start Menu => Siemens NX ... => Post Builder
I believe, that is in Native NX
With Teamcenter, I do not have standalone software, only if I can access it from NX 11
Try this post, if not perfect, you can modify it...
Post Builder was never integrated into NX, it is always started from the Windows Start Menu.
There is no difference if you use managed or native NX in this regard.
I found the post_builder.exe but looks like I am missing libsyss.dll
Don't be so naive and run any of the NX executables directly, the only way is to use the start menu entries.
Ok, I have to see, I do not have it in Start menu ....
