Re: Postprocessor - skip first operation
  1. save the current value of the variable
  2. call the code to create the tool list
  3. reload the variable with the saved value
You will have to do this for any variable you are trying to use without modification.
What about after the tool list trying?
global mom_your_variable_name
catch {unset mom_your_variable_name}
Glenn Balon
Production: NX 12.0.2 MP7 Primarily CAM
Somewhere I saw code to save/restore all  the "globals" around a shop docs call - was it in one of the weekly symptoms/solutions articles?  I'll try to track it down.
The other option (that I would use) is to write a small, separate post, that JUST creates the tool list.
Then use "MOM_run_postprocessor" to run that instead.  You'll have to fold the output file back into the original post's output file, so, depending on your knowledge of tcl, it may be a case of "choosing your poison" ;-)
Thanks all for the help.
Catching and setting the op_type variable after the tool list call has solved the issue.  I appreciate all the information.
David
Finally found the code I remembered to save/restore tcl variables around a "shop docs" call.
See this thread:
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/Machine-time/m-p/4...
2 procs in one of the replies:
PB_CMD_StoreMomVars {}
PB_CMD_RestoreMomVars {}
Thanks Ken, I'll take a look at it.
dc
