Previous Tool in Post
We have an older Mazak with a Fanuc 6m control that uses pocket zero in the tool change sequence.I want to be able to change the post in Postbuilder to accommodate this.Currently using a Haas post and editing it by hand. Machine also must go home in Z for every tool change
                                  Example of an edited post
Thanks for you help
