Problem about Gouge check
I am using NX 9.0.3 MP2 . When I use gouge check in CAM . It has long time about 1 hour . this is a bug ?
Re: Problem about Gouge check
That sounds like a long time, but it depends on many factors, such as the size of the part and tool, the tolerances and clearances you are using, and your computer.
How long did this take in prior releases? If it was much faster, then this could be bug, so please report this test case to GTAC so they can take a look at it.
Mark Rief
Retired Siemens
Please report this case to GTAC. Development would very much like to figure out what's taking so long but we'll need your data to be able to do so.
