Problem about Machine tool builder
Dear all
I am using NX. 10.0.2 . Now I create new machine ( 5 Axis with dual head rotate) . I found some problem when I  use machine tool path simulation . but X axis is moving error(see attach file) . please anyone tell me about this problem .
Thank you
Re: Problem about Machine tool builder
Where placed Machine Zero? What initial value for X Axis?
Dear all
OK, I can solve this problem. Solution is set X axis reverse .   Axis X+ is set go to left side.
thank you
