Problem with CORNER_ROUGH
CORNER_ROUGH toolpath calculations incorrect
I am trying to find the same CAMTOOL selection parameters
who can help me
Thanks!!
Re: Problem with CORNER_ROUGH
hi,
first of all, you should put both operations under the defined workpiece.
1.
operation corner rough: is looking into the areas where bigger previous tool cant fit. only.
Your previous tool/operation can reach deeper - set ramp length smaller and smaller..finaly to 0 and you will reach to maximum depth with D10.
After then corner rough will have more logic for you in this case.
But you know corner rough doesnt check previous path, only previous tool diameter.
So what you did with previous tool is on you.
2.
other possibility
if you want to mill the rests -  use ipw and no referenced tool.
