Problem with PLANE SPATIAL..
I have some problem with ISV simulation.
I created an operation using a fixed axis and then performed a machine simulation.
A 'Rotary Limit' error message appears on the line where the 'PLANE SPATIAL' code is output.
How can i solve this problem?
I used NX10.0.3.5 and recycled 'sim_14' Exsamples.
Machine Type is 'DMG DMU40evo_5axis BC-TT'.
Please need your help..
issue1.jpgError message.issue2.jpgAxis info.
5 REPLIES 5
Re: Problem with PLANE SPATIAL..
before speculating or start digging into the details, do you have the possibility to check that against NX11.0.1?
Thomas Schulz
Siemens PLM
I already did.
NX11.0.1 same problem detect.
Thanks.
The simulation of PLANE SPATIAL using the soft limits of the machine tool to find a solutions. * Are you sure the programmed operation can be machines within the given limits?
You may also could check some settings of global variables in the MCF file.
I responded here to a similar topic
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/ISV-message-quot-u...
Thomas
Thomas Schulz
Siemens PLM
If the problem still exist... fill out the global variables correctly.
2017-04-21 10_33_59-Machine Configurator - [G__kits_mach_resource_library_machine_installed_machines.jpg
Good Answer!
I didn`t know that...Smiley Sad
Thanks you!!!!!!
