Problem with chamfer tool
Hello everyone.
For some time I am using the procedure: "PB_CMD_create_tool_list" in my postprocessor.
Everything is almost ok
But....
I have a problem when I use the chamfer tool.
Then the procedure can not see this tool.
When I change to another tool (End mill) then everything is good.
How to fix it ??
3 REPLIES 3
Re: PB_CMD_create_tool_list - problem with chamfer tool
If you search this forum, you will find there's a fair number of tool types not supported by the tool list functions.
You will have to figure out out what tool type it is & add appropriate code.
You can make a workaround.
In the procedure PB_CMD_MAP_TOOL_TYPE_AYS add the other type of tools...
global mom_tool_type
if {[string match "Milling*" $mom_tool_type]} {
return "MILL"
} elseif { [string match "User*" $mom_tool_type]} {
return "MILL"
} elseif { [string match "Turning*" $mom_tool_type]} {
return "LATHE"
} elseif { [string match "Grooving*" $mom_tool_type]} {
return "LATHE"
} elseif { [string match "Threading*" $mom_tool_type]} {
return "LATHE"
} elseif { [string match "Drilling*" $mom_tool_type]} {
return "DRILL"
} elseif { [string match "Spot*" $mom_tool_type]} {
return "DRILL"
} elseif { [string match "Reamer*" $mom_tool_type]} {
return "DRILL"
} elseif { [string match "Thread*" $mom_tool_type]} {
return "DRILL"
} elseif { [string match "Tap*" $mom_tool_type]} {
return "DRILL"
} else {
MOM_output_literal "(Type of tool unknown $mom_tool_type in procedure tool_list)"
return ""
Best regards,
Thank you very much for your answer.
Best Regards
