Problem with export part from Solid Edge to NX cam EXPRESS, pression the shortcut for CAM EXPRESS
I create the part, when press the shortcut for CAM express in the SE enviroment, NX starts up but the part not. The screen stays in the welcome, does anyone knows how to fix this?
NX 9.0, Solid Edge ST6 with MP3
1 REPLY 1
As answered in the GTAC support forum, if you installed N...
As answered in the GTAC support forum, if you installed NX/CX9, and then ST6, this this should work fine.
It soundls like you followed the instructions to run ST6 with NX/CX8.5, and manually installed the plmxml adapter. If so, uninstalling and reinstalling ST6 should correct it.
