Problem with turning-tools in NX12
Hello!
We are working with NX12.0.2 MP5 in Teamcenter 11.4.0.6
From all tools we use we have 3D-solids in TC.
In our CAM-Setups we use POCKETs.
If I open two CAM-Setups, which include turning-tools and I want to change into the second CAM-Setup I see that all turning-tools are loaded again. If I change back to the first part all turning-tools are again loaded and so on. You see it in the status-line at the bottom.
If I change to Machinetool-Navigator this happens too.
This happens only with turning-tools if the are positioned in POCKETs and in TC-environment.
If the turning-tools are outside of a POCKET it does not happen.
In NX10 we did not have this problem.
GTAC cant reproduce this problem.
Does anyone else has exactly our constellation?
Do you also have this problem?
Thanks for help.
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
1 REPLY 1
Re: Problem with turning-tools in NX12
Video or clear photos highlighting the problem and information about your CAM setups, cutting tools configuration in Teamcenter would help to understand the issue.
