2 weeks ago - last edited 2 weeks ago
Hello!
Is there a known problem in NX12 with turningtools which are located under a pocket?
Every time when we change to a different part or if we change from Operationnavigator to Tool-Machine-Navigator and back all the turningtools which are located under a pocket are loaded again. We work in TC. It takes a long time. Milling- and Drillingtools doesen't have this behaviour.
If I locate the tools outside the pocket the tools are not loaded again.
It does not matter if it's a lathe or a milling machine. The key is the pocket.
A different key is TC. Nativ it works without problems.
Please look at the movie.
Thank you all for answering.
Tuesday
This problem is not known by the NX CAM and MRL development teams.
I suggest to open a GTAC call for this problem.
NX 10 is not under maintenance anymore. This means most likely there will be no fix in NX 10.
You could also do a test with a newer NX version and check if the problem is already solved in the new release.
Hope this helps...
Markus
