Problems and Bugs with NX 9.0.3.4 Mp01?
Good morning, yesterday I installed the last maintenance package available for NX 9.0.3 and now the Simulation doen't work anymore.
I receive this error.
Any idea or suggest?
The firt time that I launched the maintenca package (using the .exe file), I obtained an error in a file, so I tried with .bat.
The location of the files is correct, I installed any maintenance package and version from 8.0 to 9.0.3
Siemens NX 9.0.3.4 MP01 on Windows 8.1
Re: Problems and Bugs with NX 9.0.3.4 Mp01?
when do you get this error message? For help I need more details! In Manufacturing? In MachineToolBuilder? Internal/External Simulation....
Machine Tool Enablement
Good morning Thomas,
I receive this error when try to simulate the toolpath.
Here you are a video recording of the problem
I am afraid that the first time that I launched the .exe something gone wrong..  Probably with the Window system registry.
In the past I had similar problem and had to format the pc to resolve.
Good Morning,
I´ve good and bad news... at first the bad one... it´s a known bug in NX903MP1.
Now the good one. There is a workaround to avoid this problem.
  • Switch the NX language to "ENGLISH"
OR
  • go to NXFOLDER\LOCALIZATION\ and rename „ug_cam_YOURLANGUAGE.dpx“ to „ug_cam_YOURLANGUAGE.dpx_org“
  • copy NXFOLDER\UGII\ug_cam.dpx to NXFOLDER\LOCALIZATION\
  • rename this file to „ug_cam_YOURLANGUAGE.dpx“
Please give us feedback when it works.
Thanks and sorry for this inconvenience
ThomasF
I've just made the file editing (I copied the ug_cam.dpx from UGII folder, pasted end renamed in LOCALIZATION folder).
Now it works, I can use the software now.
For your information the page of "Tool simulation" is different from the past, now I have only "Replay" and "3D simulation".   2D simulation is not on available.
In the attachment I send you the screenshot.
this sounds good! Smiley Happy
Take a look into "What's new in NX 9.0.3 MP1 --> Manufacturing ---> Integrated Simulation and Verification (ISV)"
If you want to restore the tab, change your customer defaults as described in "Whats New"
ThomasF
Thomas,
Where can I find the What's New documention for 9.0.3mp01?  For some reason I am unable to find it.
NX 11.0.2
You´ll find it on your installation DVD/ISO/ZIP
nx-9.0.3.mp01-64bit-download_from_GTAC\REL_INFO\maint_docs\nxmr903\index.html
ThomasF
