Problems with 3D Material removing CSE
NX 9.0.3.4
Hello!
I have a problem with 3D Material Remove checkbox.
I set simple cylinder as Workpiece for my simulation project:
But when I start simulation and try to set checkbox "Show 3D Material Removal - next moment I see ERROR MASSAGE:
What kind of type expected!?
And - few lines from log-file:
&MACRO ASK_ITEM 9306112 (1 BOOL 0) = 1 ! Show 3D Material Removal
PK function PK_ENTITY_delete failed, ifail PK_ERROR_wrong_entity (10), severity Mild
Failing argument entities (2), entity 0, index 0
*** EXCEPTION: Error code 820010 in line 1844 of o:\ugnx903\ip4\src\dman\no\ind\ki_errors.c at Sat Aug 29 12:37:34 2015 RTZ 2 (зима)
+++ PK ifail 10 from PK_ENTITY_delete
[ 1] 07FEFD52B3DD (KERNELBASE)
[ 2] 07FEDBB0C80E (libsyss)
[ 3] 07FEDBB4658D (libsyss)
[ 4] 07FEDBB4628B (libsyss)
Re: Problems with 3D Material removing CSE
I set back Customer Defaults for Needle Counts and Tolerances - it solve a problem.
Can you log a PR with yout example?
We had a similar issue comparing IPW accuracy for verify when eedle count and tolerance modes were mixed.
Mark Rief
Retired Siemens
