Python Parser - How get Variable value?
How I can compare inside Python parser (yacc-file) any Variable Value with integer? I have error incompatible types...
For example, I want to compare #5 and 0:
        index = self.exprFactory.CreateVariableExpr('#5')
        if index > 0:
            some code
Re: Python Parser - How get Variable value?
Hi Chigishev,
I am not sure, can you maybe cast the value before using it like:
if float(index) > 0
I am guessing only
Thomas Schulz
Siemens PLM
