Query in dbc_tool_ascii.def
Hello!
I want to change the dbc_tool_ascii.def and I see that the following query does not work:
CLASS TOOL
TYPE QRY
QUERY "[DB(libref)] != [0]"
DIALOG libref
RSET libref Descr MaterialDes
UI_NAME "Tool"
CLASS DIFFERTOOLS
TYPE QRY
QUERY "[DB(Type)] == [02] || [DB(Type)] == [03]"
DIALOG libref Diameter TaperedSDia Descr
RSET libref Descr Diameter TaperedSDia MaterialDes
UI_NAME "Differ"
CLASS DIFFERENT
TYPE QRY
QUERY "[DB(Type)] == [02] && [DB(SubType)] == [01] || [DB(Type)] == [03] && [DB(SubType)] == [02]"
FILE "qry=shank_mill_schema;rset=shank_mill_schema;"
DIALOG libref Diameter FluteLength CorRadMill TaperAngleB TaperedSDia Material Holder Descr
RSET libref Descr Diameter Type SubType FluteLength CorRadMill TaperAngleB TaperedSDia MaterialDes HolderDes HolderRef
UI_NAME "Differ_Tools"
For better representation:
2015-12-02 08_48_03-UltraEdit-32 - [C__Ugs_NX10_MACH_resource_library_tool_ascii_dbc_tool_ascii.def].png
As result I get
Type 02 Subtype 01
Type 03 Subtype 01
Type 03 Subtype 02
Type 02 Subtype 03
Type 03 Subtype 06
Type 03 Subtype 07
Type 03 Subtype 21
Type 03 Subtype 22 ...
I only want to get
Type 02 Subtype 01
Type 03 Subtype 02
Any ideas what I do wrong?
Thank you all for your help.
Werner
Werner
Production: NX10.0.3, FBM | TcUA 10.1.2.2
Development: VB.NET, Tcl/Tk | Testing: NX12.0
Re: Query in dbc_tool_ascii.def
Siemens Genius Siemens Genius
Siemens Genius
Hi Werner,
Probably solved when using a couple of parenthesis
([DB(Type)] == [02] && [DB(SubType)] == [01]) || ([DB(Type)] == [03] && [DB(SubType)] == [02])
Toon
Make sure to use curly braces Smiley Wink
QUERY "{[DB(Type)] == [02] && [DB(SubType)] == [01]} || {[DB(Type)] == [03] && [DB(SubType)] == [02]}"
Hello!
Without any bracket I get result 1114
With round brackets I get result 0 tool
With curly brackets I get rersult 1114 tools
With square brackets I get rersult 1114 tools
You can try it on a OOTB-System with my changed queries.
The idea with the bracktes I already had.
The brackets do not help.
Werner
Werner
Siemens Genius
Hi Werner,
Using your query on the ootb ascii library I do get differences
Query differences
On the left
On the right
 But you're right, with or without brackets don't make a difference here ..
Toon
Hello Toon,
if I enter the Query in the dialog it works with the brackets. But if I enter the Query in the DEF-File like I did it, it does not work. Please try it out.
BUT: If I enter the Query in the first Class-Level it works:
It works:
It does not work:
Is that logical?
Thanks for help.
Werner
Werner
This might be a problem with the parser, try escaping the curly braces.
QUERY "\{[DB(Type)] == [02] && [DB(SubType)] == [01]\} || \{[DB(Type)] == [03] && [DB(SubType)] == [02]\}"
Hello Stefan,
if I do that then I get a parser-error:
+++ Query: Parsing failed on string \{[DB(Type)] == [02] && [DB(SubType)] == [01]\} || \{[DB(Type)] == [03] && [DB(SubType)] == [02]\} && [DB(Type)] == [02] || [DB(Type)] == [03] && [DB(libref)] != [0].
There I can see how the query works:
Obviously the Query goes from the lowest Class to the top class and adds them into one query. There I see that the logic can't work.
Werner
Werner
Siemens Genius
Hi Werner,
You're right. The cumulative query adds the subqueries, connected by "&&".
You probably should put brackets around each sub-query
{[DB(Type)] == [02] || [DB(Type)] == [03]} having the resulting query as
{[DB(Type)] == [02] || [DB(Type)] == [03]} &&
{{[DB(Type)] == [02] && [DB(SubType)] == [01]} || {[DB(Type)] == [03] && [DB(SubType)] == [02]}}
Toon
