Radius is not cut away to the center.
Radius is not cut away to the center, how to solve this.nx 9
Re: Radius is not cut away to the center.
Peter, I see you have not been back since posting this. If you are still looking for help, can you provide some more information? I see this part, but I don't understand your question.
Mark Rief
Retired Siemens
Hey,
I've already been in touch with the helpdesk and the problem has now been resolved. thank you for your comment.
Regards, Peter
