Remove last member NX11.01
Hi
After updating to NX11.01, I am seeing new dialog for part boundary creation. But where is "Remove last Member" button?. If we select a wrong edge while selecting part boundary there seems no way to deselect that.
Re: Remove last member NX11.01
Expand all groups of the new dialog and check the one that lists the boundary members, there you can select the member to delete, if I remember correctly.
The boundary dialogs are now the same for all boundaries, in NX 10 only the boundary dialogs for planar milling operations were the only old ones.
I tried to deselect with "shift" key .. and it works. But must be aktive Select Curve (orange beckground). After deselecting member it sometimes jumps to member dialog. So try it.
I worked with planar mill operation, select part boundary, curve selection method
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Thanks, Holding shift and clicking on curve worked!. Although I wish we could add or remove curves from existing boundaries.
The boudary dialog uses standard NX selection, so in addition to shift-select, be sure to pay attention to the selection filters and intent rules on the selction bar.
Mark Rief
Retired Siemens
