Removing selection stickness NX Journaling
trying to write journal for cam operaions
how do I remove selection stickness in following lines:
Dim objects1(0) As NXOpen.CAM.CAMObject
Dim nCGroup1 As NXOpen.CAM.NCGroup = CType(workPart.CAMSetup.CAMGroupCollection.FindObject("NC_PROGRAM"), NXOpen.CAM.NCGroup)
objects1(0) = nCGroup1
Dim isvControlPanelBuilder1 As NXOpen.SIM.IsvControlPanelBuilder
Re: Removing selection stickness NX Journaling
Try the "stickiness" link from this Solutions Database article
https://solutions.industrysoftware.automation.siemens.com/view.php?q=journal+remove+stickiness&dt=&r...
There are several samples in the UGOPEN\SampleNXOpenApplications\.NET\CAM folder. Look for those with "OntSelection" in the name.
Mark Rief
Retired Siemens
