Report Shortest Tool Length - Why the need to Ok every toolpath result?
Is there an easy way to fix this? It would be nice to be able to do this to a bunch of toolpaths and have the ability for the program to calculate in the background without sitting there staring at the screen....
Dennis Rathi
Creations Unlimited
Re: Report Shortest Tool Length - Why the need to Ok every toolpath result?
Have you tried with a journal?
There is an ONT column for the shortest tool, so not doing it interactively, but through a journal could help here.
How would I do that? I'm not familiar with journals at all...
Dennis Rathi
Creations Unlimited
  1. Record a journal of the interactive procedure to get the shortest tool length of one operation
  2. Edit the created source code to work with the OperationCollection
Here is an example.
' NX 10.0.2.6
' Journal created by Stefan.Pendl on Fri Nov 06 08:39:01 2015 Mitteleuropäische Zeit
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
    Sub Main (ByVal args() As String)
        Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
        Dim workPart As NXOpen.Part = theSession.Parts.Work
        Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim theUI As NXOpen.UI = NXOpen.UI.GetUI()
        workPart.CAMSetup.MinToolLen(workPart.CAMSetup.CAMOperationCollection.ToArray())
    End Sub
End Module
The problem is that it still asks for user confirmation.
I think we need to file an enhancement request to get this done in the background without user interaction.
It even doesn't make sense to have the user confirmation displayed, if the action is run from a journal, since there is an ONT column to display the result.
