Resource Management - Setup Sheets - Minimum NX Versions
Siemens Genius Siemens Genius
Siemens Genius
The Teamcenter Resource Manager application allows to create automatic setup sheets for tools and other resources.
Below you can see an example of a setup sheet.
Here is the information what minimum NX versions (Graphics Builder) are required to use this functionality.
The general MRL Setup Sheet functionality is available in those NX versions:
  • NX 10.0.3 MP6
  • NX 11.0.0 MP5
  • NX 11.0.1 MP1
  • NX 11.0.2
  • NX 12 and later
If you want to use inch setup sheet templates, you need at least those NX versions:
  • NX 10.0.3 MP19
  • NX 11.0.1 MP6
  • NX 11.0.2 MP3
  • NX 12.0.0 MP1
  • NX 12.0.1 and later
Teamcenter Help Documentation explains, how to set up and how to customize setup sheets:
Home > Managing Manufacturing Data > Resource Manager > Administering resource management
Setting up and customizing setup sheets
Hope this helps...
   Markus Dietz
nxt_mill_02_00001_A.pngMRL Setup Sheet
