Reuse library in CAM
Honored Contributor
Honored Contributor
I have the sample CAM reuse library files that Siemens has available, clamps, vice, paralells, etc.  The CAM guys just pointed out to me, that the reuse library looks different when in the Manufacturing application vs. the Modeling application.  They would rather stay in Manufacturing, and add whatever components they need, vs. going back and forth.
Is this possible?  and why is it different?
CAM:
Modeling:
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
3 REPLIES 3
Re: Reuse library in CAM
Honored Contributor
Honored Contributor
Never mind, I finally found where to turn it on for manufacturing.
-Dave
I don't know why they are different, but I would think it would be because certain re-use components might only be able to be used in either drafting, modeling or manufacturing.
Using NX 8.0.3.4
Honored Contributor
Honored Contributor
fyi, right click on the Reuse Library column area, you get the option for Reuse Library Management.  Here you can set which library sections are available in the different applications.
-Dave
