Reusing blank (IPW) from different workpiece
It seems that NX 10.0.3 MP14 has changed the way one is allowed to reuse the resulting blank of a previous workpiece group.
It seems to be no longer necessary to follow the rules below:
  1. identical geometry must be used
  2. placement is based on separate components
It seems that it is now possible to select the previous workpiece as the IPW source even if it contains support geometry that is not present in the current workpiece.
The orientation of the IPW is based on the parent MCS instead of the orientation of a component.
Can someone confirm this much appreciated change in behaviour?
Re: Reusing blank (IPW) from different workpiece
Hello Stefan,
which function you are refer too?
ONT, Verify or ISV with CSE?
I am not aware of any specific change in NX10.0.3 in ISV CSE.
Thomas Schulz
Siemens PLM
Hello Thomas,
it is the regular blank definition inside of a workpiece group, see images below.00_AssemblyStructure.PNGAssembly Structure
01_ONTgeometryView.PNGONT Geometry View
02_SourceWorkpiece.PNGSource Workpiece
03_DestinationWorkpiece.PNGDestination Workpiece
04_BlankDefinition.PNGBlank Definition
Hope this clarifies my request.
Hi Stefan,
yes it clarifies, but I do not know changes in that area IPW definition inherit in NX10.0.3.
Hope others knows the details and can help.
Thomas
Thomas Schulz
Siemens PLM
Hi Stefan,
The positioning per CSYS was done in NX11.0 (IPW Positioning Type --> Part or CSYS in Blank definition)
In NX10.x we have also relaxed a constraint concerning identical part geometry (As you have mentioned).
It will stay like this, no worries :-)
Glad it helps you.
Oliver
Hi Oliver,
thanks for the clarification that you have removed the restriction that the geometry must be the same.
This will be a big leap forward, when I inform the users of this in our next NX consultation meeting.
