Right way mount turning tools in simulator
I would like to know which is the right way to mount the turning tools in simulator, I have some problems using the NX default MILLTURN example (sim10), the default tool direction is not correct.
Thank you
Re: Right way mount turning tools in simulator
Please explain your issues more in detail.
Otherwise we can not dublicate your problem.
Thanks.
Jürgen Becker
SIEMENS Industry Software GmbH
NX CAM Product Management
Manufacturing Engineering
Franz-Geuer-Str. 10
50823  Cologne, Germany
Tel.      :+49 (221) 20802 321
Fax      :+49 (221) 20802 566
Mobile :+49 (1520) 8350716
beckerjuergen@siemens.com
www.siemens.com/plm
