SFB-NX-9430 - Postbuilder 10.0.x issues
For those experiencing Postbuilder 10 problems, please review this SFB.
The complete SFB containing the details and PR numbers is available from GTAC.
                S O F T W A R E                 SFB-NX-9430
                F I E L D                       Page 1 of 2
                B U L L E T I N                 Issue Date: Sept-14-2015
                                                Revision Date: Sept-14-2015
                                                Supersedes: N/A
                                                Submitted By: Gen Lin
                                                Responsible Group: GTAC CAM
                                                GTAC 800 # Options(s): 2,1,1,3
   SUBJECT:  Multiple critical issues with Post Builder v10.0.x
   Affected Software: NX Post Builder v10.0.x
   PROBLEM:
   Several critical issues have been found with Post Builder v10.0.x as listed below.
   REMEDY:
   This issue can be resolved by:
        1) Downloading the PBv10-SFB-NX-9430.7z from our ftp site located at:
         https://download.industrysoftware.automation.siemens.com/unigraphics/cam/
   If any questions arise regarding this field bulletin, the
   Global Technical Access Center may be contacted at:
               All USA & Canada                (800) 955-0000
   If you are outside the United States and Canada, any questions
   regarding this or any other SFB should be directed to your local
   support office, quoting the SFB number.
Mark Rief
Retired Siemens
Re: SFB-NX-9430 - Postbuilder 10.0.x issues
Hello Mark,
Thanks for posting this here I have downloaded this and so far it has resolved all the issue I was having.
Greatly appreciated.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Vericut 7.3,7.4.1,8.0.2
Do these problems occur with post processing programs with NX 10 and post builder 10?
Using NX 8.0.3.4
Esteemed Contributor
They occur if you edit existing (and/or new) posts with PB 10.
If you don't touch your posts with PB10, they should continue to work "as is" (more or less)
As Ken said only when you tried to edit or save in Post builder NX10.0.2 was there any issue.
As I said before I downloaded the update and all seems to be working as you would expect.
Hope all have a good day.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
