STL machining using 4 axes with NX
How mill Stl using 4 axis in NX?
Thank you!
Richard
Re: STL machining using 4 axes with NX
I think that STL is not yet supported by the multi axis processors, but it is on the road map.
Attached find a journal with block dialog to convert a faceted body into faces, which takes quite long for many facets, but it is a start.
Afterwards you can sew the resulting face bodies together to get a solid body.
How to use this feature in NX?
Thank you!
The DLX file must be placed in any application sub-folder of UGII_SITE_DIR, UGII_GROUP_DIR, UGII_USER_DIR or the folders specified in custom_dirs.dat, than it can be found by the journal or DLL.
This is the regular rule for any block styler dialog based customization.
Am I doing something wrong?
*UGII_CUSTOM_DIRECTORY_FILE      C:\NX11\ugii\menus\custom_dirs.dat
*in custom_dirs.dat I have wrote this: c:\stltosolid
*dlx file is in C:\stltosolid
when I run vb file from desktop and It gives me an error like Richard showed
Any idea?
thank you
These folders need to follow a defined structure.
A small explanation is included in the ugii_env_ug.dat file with the variable UGII_VENDOR_DIR, the complete description is in the NXOpen API user guide.
Short answer, you need to add a folder called application below the folder you specify and put the files there to make NX happy.
I had emphasized the application folder in my previous post, seems it didn't stick out enough.
