Re: STL to Solid Body. Get it!
Gap 2:
convergent bodies are not yet supported by CAM, only support is for NX facets and only for a limited amount of operation types
STL file display is fine.   Why I output STL only one facet after transfer from STL to  Model?
Upload your stl, please
Please see the attached file.
STL-file MUST BE ASCII-file (text, not binary). Set this option when will be output STL. Your file is binary now.
For @UGPLM!
I save your file as ASSCII (see attached), import it and add Sew, and after Sew add Sync Modeling->Optimize Face. Not so bad for block 245x215x50
Thanks,@
I get the result like this. It looks good!
Thanks.
Good!
Tried your makros, it passed as you described. 2000 nonparametric solids, but problem is that all of them at the same location! I mean 2000 the same truangulars in spot. It seems during creation the same coordinates were used through cycle. Do you know how to cure this? do you have shared code for you dll?
thanks
e
