Re: STL to Solid Body. Get it!
Can you upload your STL?
Hello, it,s just design default featire, exported to STL, for example cone, or block.
You told that only text format of stl dll works with. But when i run your dll, it requires to point out stl, nx allows me choose only binary file!
With binary file happens situation as i told above. Maybe there is special way to save such text format of stl?
I working with nx10.
E
When you make STL export you can choice binary or text (may be you will need to rename txt file to stl)
Yes, I know that there are two types of save, but when I run the dll, in folderdialog where need to choose stl, I cannot choose stl.txt file(first picture). I don´t know how to save  text stl in different way, only txt file(second picture)
thanks
e
Just rename your stl.txt to stl.stl
got it!, it works, thanks for support!
is it possible to share this code for modification of my needs?
thanks
e
Could you give me a favor to test one stl? i´m interesting which result you get. I got triangulars not from full part
here is attached file.
thanks
e
33364 facets. PRT NX10 - here - https://cloud.mail.ru/public/62rp/5SfYGHzBD
Hello, thanks for your test. Unfortunately my result not so nice as yours. I got only piece of the part recognized, 2000 nonparametric bodies (created facets), please result:issue.jpg
How did you get whole part recognized? Maybe there are some options in your dll, whch i missed(num of facets)?
thanks
e
You might find this discussion useful.
山田
yamada
