Sequential Mill Help
Can someone please help me with why this operation is going all the way around the boss and gouging the part. This is done in NX 10
6 REPLIES 6
Re: Sequential Mill Help
Hello.
Not sure if it helps, I did it using contour profile...
Wave link body is on layer 40 ...did some synchronous modeling to clean up the machined areas...
Kal.
File attached.
NX 9.0.3.4 MP12 | PB 9.0.3.2 | NX11.0.2.7 MP13 | PB 11.0.2 | VERICUT 7.3.4
Yes that does work thank you for your time. I use contour profile alot and I have been trying to learn more sequential mill.  I would still like to find out what im doing wrong with sequential mill.
It look like the added corner fillets are causing the tool to go all the way around the boss after the path it generated.
You can turn off the  "corner control >  fillets" on the first page or from step 17 on, change the tool axis to 3-axis same.
HTH Eric
Turning the corner fillets off does not seem to keep it from going around the boss.
MainwCrn.jpgWith CornersMainWoCrn.jpgWithout Corners
Ok i did get the results you did after turning off corner fillets at the very start of the operation. But then I dont have the fillets which i need. Thank you for the help.
