Set Machining Data for drilling / peck depth
I did some searching around and did not find what I was looking for. Is there a way to get set Drilling Peck using the Machining data / feed speed?  For milling tools it works just fine. Peck.JPG
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Re: Set Machining Data for drilling / peck depth
It's not in the out of the box machining database, and I'm not sure if it's possible to add that. You should be able to set this with FBM, or at least a good default in your templates.
Mark Rief
Retired Siemens
