SetStopAtCollision
Hi!
I need any explanation about SetStopAtCollision....
For example, I want to stop counter-spindle motion when chucks will touch part geometry.
I need ANY EXAMPLE of this function.
Thanks.
12 REPLIES 12
Re: SetStopAtCollision
Please help us by being a little more specific - Where do you find this command?
UI? API? mom? ISV?
Mark Rief
Retired Siemens
Excuse me, this command for CSE simulation,  Machine Configuration.
Hi Chigishev,
take a look into the sim15 OOTB example. There we defined the M-Commands M120/121 M130/131 to open/close the chucks. If you need further information let me know.
reagrds
ThomasF
Machine Tool Enablement
Thank you, Thomas!
Working. My fault was - I set 4 parameter as "MAIN_SPINDLE", but must be "CHUCK", as real clamping device.
Thank you for idea!
Smiley Happy
Thanks for your feedback!
Hi everybody,
I'm testing collision stop with NX 12.01. and also with older NX versions I don't get a stop with a _WORKPIECE classification. Just a collision with _PART component works.
XML Code:
<Command>
<Name>ResetMotionStopCollision</Name>
</Command>
<Command>
<Name>SetStopAtCollision</Name>
<Param>"Table_Parts"</Param>
<Param>""</Param>
<Param>"All_Others"</Param>
<Param>""</Param>
</Command>
or:
<Command>
<Param>"MAIN_SETUP"</Param>
</Command>
I hope you see a big mistake Smiley Happy
Regards, Viktor
Hi VikP,
please show us the configuration and the classification of the Setup components (Part, Workpiece)
thanks
Thomas
Hi Thomas,
what do you mean with "configuration"?
Regards, Viktor
I can assume you added graphics to MAIN_WORKPIECE and MAIN_PART?
