Shop Doc Excel Template
Hello there,
I have run into problems in the Excel Template for Shop Doc.
1. Get the sum of two numbers.
http://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX/NX-9-Shop-Docs-Common-Que...
I have done as instructed in the above link, used the following expression, but still cannot get the sum in column six, even when I displayed the html output in Excel.
'= ${mom_tool_length} + ${mom_tool_tapered_shank_length}
Please find the template attached.
2. In my tool list, I list the operations that use the same tool. How can I output the spindle speed of each operation? I want to combine the tool list template and the operation list template, but it seems that the template is constrained by the .tcl code.
Kai
5 REPLIES 5
Re: Shop Doc Excel Template
The Excel template is only filling out variables, it is not doing any calculations.
To have calculations working, you will have to add a custom variable that contains the result of the calculation and edit the Tcl script to calculate the value of the custom variable, I think.
Thanks, Stephan.
I wrote the following lines in the file "shopdoc_excel.tcl". When I tried to get the shop doc in NX, a message poped up "No such variable: mom_tool_length".
 global mom_tool_length mom_tool_tapered_shank_length mom_tool_total_length
 set mom_tool_total_length [expr $mom_tool_length + $mom_tool_tapered_shank_length]
Kai
add this in a cell to the right of you shop doc to keep it from being printed
'=${mom_tool_length} + ${mom_tool_tapered_shank_length}
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Thanks.
It still doesn't work.
Kai
Hello there,
I still have problem with this. It worked once, and never worked again after that.
Kai
