Shop Doc Multiple Excel versions
PLM World Member Creator PLM World Member Creator
Hello
Is it possible to set multiple versions of Excel in shopdoc_excel.tcl
We use Excel 2013 and 2016 and they have different install directory.
Now we using
# Specify proper location of the application's executable.
#set ::execute_file {C:\\Program Files\\Microsoft Office 15\\root\\office15\EXCEL.EXE}
set ::execute_file {C:\\Program Files (x86)\\Microsoft Office\\root\Office16\\EXCEL.EXE}
but it will be fine if we can set it to automatically detect right directory
 Tomaz
Production: NX11.0.2 MP01
Re: Shop Doc Multiple Excel versions
You can use file exists to check for the existance of a file or glob to list all files matching a pattern.
Thanks, I will try
i try this
if {file exist {C:\\Program Files\\Microsoft Office 15\\root\\office15\EXCEL.EXE}
else
set ::execute_file {C:\\Program Files (x86)\\Microsoft Office\\root\Office16\\EXCEL.EXE}}
but I get error message
&MACRO MESSAGE_TEXT File name: o:\ugnx1102\ip7\src\camsmom\no\ind\mom_tcl_definitions.c, line number: 1411
&MACRO MESSAGE_TEXT Error Message: TCL error returned when evaluating file X:\Unigraphics_SETUP\NX110custom\NX110library\CAMresource\shop_doc\excel_templates\shopdoc_template.tcl
&MACRO MESSAGE_TEXT Trace: syntax error in expression "file exist {C:\\Program Files\\Microsoft Office 15\\root\\of...": variable references
&MACRO MESSAGE_TEXT require preceding $
&MACRO MESSAGE_TEXT ("if" test expression)
&MACRO MESSAGE_TEXT while compiling
&MACRO MESSAGE_TEXT "if {file exist {C:\\Program File
&MACRO MESSAGE_TEXT s\\Microsoft Office 15\\root\\office15\EXCEL.EXE}
&MACRO MESSAGE_TEXT set ::execute_file {C:\\Program Files\\Microsoft
&MACRO MESSAGE_TEXT Office 15\\root\\..."
&MACRO MESSAGE_TEXT invoked from within
&MACRO MESSAGE_TEXT "if { $__display_output_ext_app && [string match "win
&MACRO MESSAGE_TEXT dows*" $::tcl_platform(platform)] } {
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT #--------------------------------------------------------..
&MACRO MESSAGE_TEXT ."
&MACRO MESSAGE_TEXT (file "X:/Unigraphics_SETUP//NX110custom/NX110library/CAMresource/shop_doc/excel_templates/shopdoc_excel.tcl" line 33)
&MACRO MESSAGE_TEXT "source "[file dirname [info script]]/sh
&MACRO MESSAGE_TEXT opdoc_excel.tcl""
&MACRO MESSAGE_TEXT (file "X:\Unigraphics_SETUP\\NX110custom\NX110library\CAMresource\shop_doc\excel_t
looks like a syntax error.
try...
if {[file exist "C:\\Program Files\\Microsoft Office 15\\root\\office15\EXCEL.EXE"]} {
} else {
Note in tcl the { MUST be on the same line as the other commands, you can't put them on separate lines
(and the "}" for the "else" has to be on the same line as the "else")
I try this and found that must be
set ::execute_file {C:\\Program Files\\Microsoft Office 15\\root\\office15\EXCEL.EXE} - missing }
} else {
and when I try output it with Excel 2016 works, but with Excel 2013 don't
If I switch lines with Excel path then works with Excel2013, but with 2016 don't
there is a error in your script :
in Tcl "" don't substitute a variable or string when you write :
} else {
you must write :
and not
Finally return 0
it's almost like I'm writing:
C:\Program Files\Microsoft Office 15\root\office15EXCEL.EXE
you should write :
file exist "C:\\Program Files\\Microsoft Office 15\\root\\office15\\EXCEL.EXE"
it s a mistake from the beginning of your code , all paths in tcl should be written :
C:/Program Files/Microsoft Office 15/root/office15/EXCEL.EXE
Don't miss {} or "" if your path has spaces
Hope que ça help
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
You must take special care about the escaping too, since there is a backslash missing too. In addition it can happen that snippets get corrupted, so you need to check what you copy for syntax errors before you use it.
Might be time to also think about taking a Tcl training.
This should be easier to use, since it avoids escaping and the block if all together.
set ::execute_file [file nativename "C:/Program Files (x86)/Microsoft Office/root/Office16/EXCEL.EXE"]
if { ! [file exists "$::execute_file"] } {
    set ::execute_file [file nativename "C:/Program Files/Microsoft Office 15/root/office15/EXCEL.EXE"]
The above uses the slash as the path separator, since Tcl uses the UNIX notation for paths.
It also sets the global variable to the native name of the path initially to avoid the ELSE clause.
Then it checks if the file does not exist ( exclamation point before the command ) and if true, sets the global variable to the native path of the other office release.
Thanks everyone.
Now working great.
Stefan, do you maybe know where I can find some Tcl training
Do you have any experience in any other software development language? As a start reading the Tcl documentation might help you figuring out the difference between the development language you know and Tcl.
Active State, the page I posted the links to the documentation, might have some tutorials, else the web might be full of them too. May be the official Tcl/Tk Wiki is a good start.
Or some books:
  • Tcl/Tk for dummies
  • Tcl/Tk for the absolute beginner
