Shop Docs Assembly show up
WE are using shop docs to show our cuts in the html. But when we run the shop doc all it shows is the insert in verify and we would like the whole assembly of the tool cutter to show up in the HTML with the cuts. Is there a preference that needs to be set in order to get this to happen? We are using 10.0.2.6
THanks
Steve
Re: Shop Docs Assembly show up
It isn't the Verify that needs to changed to Assembly. I attached an image of what it looks like right now and we would like the Red Insert to be the whole tool assembly.
