Shop Docs - Resize part picture
Is there a way to customize the size of the image that is taken when you generate the shop docs?
NX11.0.1
Re: Shop Docs - Resize part picture
if you use code html or xls :
<img src="your_image.jpg" width=100% height=100% alt="image">
Edit width or height for increase or decrease your image
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
I didnt even think to go in the file in notepad and start tweaking the native HTML.
Thank you!
NX11.0.1
Is this snippet supposed to be in the htm file? I looked in mine to no avail. Where should this be inserted?
Bill
Organization, an essential part of Productivity !
Production: NX10.0.3 MP13, VERICUT 8.0
Development: VB.NET, Tcl/Tk Testing: NX11.0, iMachining 2.0, Adaptive Roughing
Everything depends if you use a template which generates images, if it is the case you should find it in your output file *.html .
To adjust the values, you must to edit your *.tcl or *.tpl file, according to your template.
@mkn
Since the release of work instructions I've completely dropped the use of shop docs in my own shop. Check them out.
NX11.0.1
Yes with Nx10 version or more but siemens thinks of those who still work as me with V19 version 😉
@mkn
Edit the .html file in excel. You can drag the size of the image wherever you want. Just make sure to publish the .html file when you save.
Glenn Balon
Production: NX 11.0.2.7 MP4 Primarily CAM
