Shop Docs for Operations
Instead of an Image for each operation in Shop Docs that you can click on and shows where the cuts are like in the attachment.
 is there away to show the the video of what was used to create the image. Like in the 2nd attachment. We would like a video attached to each operation to show the cuts.
Re: Shop Docs for Operations
I don't know of a way to capture the video files automatically. If you capture them manually, and have a naming convention, you should be able to reference them in your shop doc.
Mark Rief
Retired Siemens
I'm Naming them the same thing as the .gif files so how would I capture them?
You could use the NX Movie command, but I would look at Camtasia or something where you can record a smaller window of interest.
Mark Rief
Retired Siemens
