Shop documentation customize
Builder
Builder
My shop documents is perfect as i need but whenver i put DRILLING operation in Operation navigator shop documents can't able to output this type of error is occure
9 REPLIES 9
Re: Shop documentation customize
It seems that you don't get a value for a operation parameter in case of drilling operations.
You will have to check if $value is equal to "--" and skip formatting in this case.
Builder
Builder
The error tells you in which procedure and in which file you have problems, it even displays the line of Tcl code you have problems with.
You just have to open the mentioned file search for the procedure and then check the line of Tcl code, to get an idea of what went wrong.
The check fails because you are checking a non-existent value. Remember that not all operations support all values.
In addition double-dash has a special meaning to many Tcl functions, so don't use it to indicate that a value is non-existent.
Builder
Builder
Let me try
Thanx
Siemens Creator
What version are you using? Is nx12.0.1?
Builder
Builder
Nx10
Builder
Builder
NX10
Builder
Builder
Problem occure
Because i set 2 decimal places in $(mom_tool_minimum_length)
So this action affect to drill
Builder
Builder
If holdout column set 2 decimal places in Excel and if drill program is available in operation list than this type of problem occurred
