ShopDOC - Mom Vars
Hello everyone !
I'm setting up ShopDoc for my company. But I have a question about which variable makes the PartStock and FloorStock appear in the process sheet. I also need the variable to check whether Cutter Compensation is enabled or not.
Appreciate
NX 12.0.1 - CAD/CAM
SolidEdge ST10
17 REPLIES 17
Re: ShopDOC - Mom Vars
Hi @MarioHP_Br,
Active The Review Tool  , You should find what you are looking for... At the end of report a Tk window will open ,you can open a debug file too (where is saved your file) and find *_stock_* .
For cutcom the variable name is : mom_cutcom_type if the variable is equal to 1 the cutter compensation is active.
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
You can use  ${mom_stock_floor}  and  ${mom_stock_part} for wall.
The problem is whem You have checked box Use floor same as side.
It will take the last value of  hidden floor stock.
Paulo Stepancic , DAG d.o.o. Koper
There is the variable called mom_stock_part_use, which indicates the setting of that check box.
if { [ info exists mom_stock_part_use ] && $mom_stock_part_use == "1" } {
    # code to handle the situation when part stock is used as floor stock
Thank You,
I will try to adopt your solution in Excell
It will not work if you set a formula in Excel.
You have to do as shown by Stefan.
The most common way is to edit your TCL script.
Adrien Marmy, Designer / SystemManager CAx, Turck Interprox
Production: NX12.0.2.mp4 | AGILE PLM E6.1.3 | ECU 3.9.9.3
Development: .NET Testing: NX18**
I have workaroud it with simple formula in Excell:
${mom_stock_part_use}*${mom_stock_part}+${mom_stock_floor}-(${mom_stock_floor}*${mom_stock_part_use})
The image below shows all situations with the checked box "Use floor same as side" and unchecked with positive and negative stock.
When I made the documentation of programs without "Use floor same as side" box, I get the output:
Then in the file" shopdoc_excel.tcl " I changed output  code.
Spoiler
       set mom_operation_name_data($mom_operation_name,$oper_var) "--"
to:
Spoiler
set mom_operation_name_data($mom_operation_name,$oper_var) "0"
and I get the output in shopdoc like this:
This was the easiest and the temporary way to solve the problem.
Hi, I tried to use the variable: mom_cutcom_type and I was not successful, is there another variable that shows when the tool compensation is active? Thank you..
I use a combination of things to drive cutcom type
Below is based on NX10 behavior.
1) mom_contact_status (note this is NOT set until AFTER custom is turned on - i..e you can NOT use this in the "cutcom on" event)
2) mom_operation_type
3) mom_tool_axis_type (4 = swarf)
4) If you have multiple types of "similar" cutcoms, you will need a UDE to select (e.g Siemens "3DFF" vs "3DF")
- If not contouring, use regular 2D cutter comp
- If 3 axis contouring, use 3D (surface normal) cutter comp
- if variable axis
----if swarf cut, use variable axis "side" cutter comp
----if not swarf, use variable axis 3D (surface normal) cutter comp
