Re: ShopDOC - Mom Vars
@DouglasECorrea wrote:
Hi, I tried to use the variable: mom_cutcom_type and I was not successful, is there another variable that shows when the tool compensation is active? Thank you..
ok , may be you can say a little bit more , what is the message ? An error ? the variable is always set to "0".
This variable doesn't works with all type of operations  and if you set cutcom with UDE
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
 @mkn
It has no error, it just shows no result. Correct, the variable starts at zero, I already used 1 and 2 for walls, but I continue with no result.
 @Ken_A
I will work on your combinations as soon as possible, when I have a result I present to you.
I really need to pay attention better & read the subject of threads....(sorry)
Note what I am doing, I am doing in the POST.
I don't use the Siemens Shop Docs module.  (I generate my "shop docs" when I post.  I may not be able to get pretty pictures, but I have access to all the data I need...)
Those variables may not exist in Shop Docs...
Below find what I use to output cutter compensation information with shop documentation.
	if {[info exist mom_cutcom_type]} {
		if {$mom_cutcom_type > 0} {
			switch $mom_cut_data_type {
				"contact contour data" {
					if {$MY_cutcom_info == ""} {
						set MY_cutcom_info "Contact contour"
					} elseif {![string match "*Contact contour*" $MY_cutcom_info]} {
						set MY_cutcom_info "$MY_cutcom_info, Contact contour"
				"centerline data" {
						set MY_cutcom_info "Center line"
					} elseif {![string match "*Center line*" $MY_cutcom_info]} {
						set MY_cutcom_info "$MY_cutcom_info, Center line"
		unset mom_cutcom_type
Hope this helps.
In which file is this written ?
Paulo Stepancic , DAG d.o.o. Koper
This must be written to your Tcl script. If you use the Excel-based shop documentation, then I cannot help you, since I don't use that at all.
Generally I dislike the dependency on MS Office.
Thanks for the help, I'll be looking for other ways to get data beyond MS office
Shop Doc Cutcom
We use the following when the Cutcom is defined within the operation.
mom_tool_cutcom_register  > .1  && mom_cutcom_type > .1
All we do is list the cutcom on/off and the number.    Left/Right or 2D, 3D etc we do not do.
You must also check whether the CUTCOM UDE has been used and turned on CUTCOM.  MOM_list_user_defined_events is documented in Siemens docs.   To get the global variables to pass to shop docs, our Shop Docs also source a tcl program with our version of the proc MOM_info_user_defined_event that MOM_list_user_defined_events is calling.   Modified to fit our needs.
