Shopdoc Setup Picture
Hello there,
I am creating my own shopdoc template and trying to output the setup image in the shop doc.
I have a .tcl file called A.tcl for generating post and a .tcl file called B.tcl that defines the format and content of the html shop doc. B.tcl is called in A.tcl, so when I postprocess operations, the shop doc is created.
The problem is how to output the setup image in the shop doc using TCL command. Since the OOTB file "Shopdoc.tcl" can be used to output the image, I searched for the relative commands from there. And found the following two commands:
if [catch { MOM_refresh_display } res] {
             INFO "$res"
if [catch { MOM_capture_image $mom_setup_part_gif_file } res] {
             INFO "$res"
I added those two commands to my A.tcl, but when I postprocessed my operation, it tells me:
invalid command name "MOM_refresh_display"
invalid command name "MOM_capture_image"
Any ideas?
Kai
9 REPLIES 9
Re: Shopdoc Setup Picture
I think some commands are really only available when you create the shop documentation from the menu entry "Information => Shop Documentation", since they are only useful for shop docs and not for regular MOM actions.
Thanks, Stephan. Is there a way to output the setup image without using the excel shopdoc template? Like a TCL command or something?
Kai
I think it is more like you have to run the code from the "Shop Docs" menu.
Note you can run a shop docs from within a post (although I'm not sure you can run the Excel shop docs from a post), but I'm not sure if that can output the pictures either.
Perhaps someone from Siemens can comment?
Hundreds of posts on this forum about how the Shop Docs are a HUGE PITA. Siemens releases the new documentation function and then sticks their hands out for more $$$$$$$$$$.
Is anyone using this yet?
Dennis Rathi
Creations Unlimited
You need to cycle objects in shop docs to get the screen capture.
[MOM_cycle_objects
    {SETUP INST='PART_GIF'
Take a look at html_oper_list.tpl for a sample.
Mark Rief
Retired Siemens
Thanks, Mark. We are trying to create a Shopdoc that can output the tools and the operations using the tools in the selected program. And output a setup picture in the beginning of the Shopdoc showing the setup of the selected program.
I am looking at the following example:
Tools and Operations (HTML), ${UGII_CAM_SHOP_DOC_DIR}tools_operations_html.tcl, ${UGII_CAM_SHOP_DOC_DIR}simple1_machview.tpl
It outputs what I want, like:
and there is a setup picture in the beginning. That is pretty good.
The problem is it outputs all the tools and operations, as it is using MACHINE VIEW:
[MOM_cycle_objects
   {SETUP
      {MACHVIEW
         {MEMBERS
            {TOOL
               {OPER
Then I tried changing MACHVIEW to SELECTED_VIEW or PROGRAM VIEW, and deleting TOOL or OPER or both, or just keeping TOOL and OPER.
The following structure gives me the closest result I want, but it outputs only the tools in the selected program, no operations.
[MOM_cycle_objects
   {SETUP
      {SELECTED_VIEW
         {MEMBERS
The following structure outputs the tools and operations in all the programs.
[MOM_cycle_objects
   {SETUP
      {SELECTED_VIEW
         {MEMBERS
		{TOOL
			{OPER
The following structure outputs a bunch of operation headers and the tools in the selected program.
[MOM_cycle_objects
   {SETUP
      {SELECTED_VIEW
         {MEMBERS
		{OPER
Other structures don't give me the result that I want, either.
Do you have any suggestions?
Kai
I found the code for generating the setup image in the .tpl file is:
[MOM_cycle_objects
        BDYT='<!--Hide [if {[regexp "/" $mom_setup_part_gif_file] == 1} {
          set setup_gif [lindex [split $mom_setup_part_gif_file "/" ] end]
        }] HTML text output-->'
        BDYT='<!--Hide [if {[regexp {\\} $mom_setup_part_gif_file] == 1} {
          set setup_gif [lindex [split $mom_setup_part_gif_file "\\" ] end]
<A HREF=\#Part><IMG src=\"$setup_gif\" BORDER=5 WIDTH=500></IMG></A>
Can I get access to the code (TCL or HTML) for generating the setup_gif file?
Kai
Bump!
Has anyone used the shop doc yet?
Do you have the setup picture in your shop doc, and both tool and operation information as well?
Can anyone please post a snapshot of your generated shop doc here?
Kai
I use the text-based shop docs without the part image here, haven't tried to convert them to HTML output yet.
