Simulation-runs only from pgm header-NX11
Can anyone tell me the reason why you cannot simulate multiple operations unless they are in a main program anymore?? (since-NX11)
Its always nice to be able to simulate a few operations when ever you wish for collision-3d-gouge checking...
toolmaker, Senior CAM engineer
4 REPLIES 4
Re: Simulation-runs only from pgm header-NX11
Which Post you use PostBuilder or PostConfigurator?
postbuider
Did you use the OOTB Simulation and Post from NX11?
In 11.0.2 the OOTB Posts changed from Postbuilder to PostConfigurator.
So you can simulate only one operation or group.
if you need to simulate 2 operations (like in your case) please made an post run before.
This post run generates a group and you can use this group for simulation.
Hope this helps a little bit
Thanks for your reply, we are already aware of the work around just wondered why this has changed as it ran better as it was?
