Solution for output more than 3 decimal places in XYZ-coordinates in post ???
Hello! I'm searching for a solution to output  more than 3 decimal places in XYZ-coordinates in post.
My coordinate-output allways is rounded to 3 decimal places. The adresses IJK I'm able to output 5 decimal places.
In postbuilder I have set it:
2017-04-06 16_40_22-I__NX10_windows64_MACH_resource_library_machine_installed_machines_cam_g550_post.png
What's wrong?
Thank you for your help.
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
Re: Solution for output more than 3 decimal places in XYZ-coordinates in post ???
In Post Builder:
- "Machine Tool" tab
- General Parameters
- What is "linear motion resolution" set to?
NOTE: for lathes where you want diameter output, there is another issue as well, but I don't want to confuse things too much...
Hey Ken! Great! This is the solution. "linear motion resolution" must be 0.00001
Sometimes I'm so blind...
Thank you.
Werner
