Speacial tool assembly display
Hey guys,
I tried to introduce special tool at NX 11.  I can see the tool in library. when i tried to see in verify, i changed tool  display with assembly. But i could not see my special tool view. In old versions i was working and also i am using same way. But i doesnt work. Some one can help me? Is there any differences in NX 11?  You can see my way in photos. tool.jpgtool2.jpg
Thanks.
Best regards.
Re: Speacial tool assembly display
Hard to get it from the picture you you shared. are you sure the operation uses the "Kilangic" tool you created? I do not have NX 11 installed, but with newer versions it seems to work.
Yours,
Eddy Finaro
NX CAM Product Manager
Siemens PLM
Yes, i am sure, i used tool which is created.
Does the folder name in the "library\tool\graphics" folder match the libref name?
Is assemblies on and enabled under the "file" menu with a check mark next to it?
Glenn Balon
Production: NX 12.0.2 MP10 Primarily CAM
Yes, i can see tool name in library file. Also assembilies is active.
Best Regards
Now it works. Thank you so much. i did not have permission to write to graphics file.
