Specify Target Body isn't working
I want to assign the attribute CAM_COMPONENT_TYPE=Target to my target component. When I have done this, in the Options of the target component, there is no Target type mentioned. Anyone experience with it?
3 REPLIES 3
Re: Specify Target Body isn't working
Hello!
Did you really push the button "Add New Attribute"? Otherwise the entry does not work.
Werner
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
well I'm working in NX7.5, so I don't have this command button. You're working with a higher version of Siemens NX.
All available options are illustrated in my images.
Greetz
after some trial and error, now it's working properly.
When I choose Edit > CAM Component type
I first have to select my target component in the graphics window, then specify as "Target" from the pulldown menu, thereafter clicking "OK".
Now, when I look at the properties of the target component, it has the CAM Component type "Target".
