Spindle Marker
Is there some way to detect in the post when a Spindle_Marker UDE has been used?  I cannot see anything on the review tool
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
9 REPLIES 9
Re: Spindle Marker
I don't know if you use the cls file or directly postprocessor , but for generate the cls file , nx use :
proc USER_DEFINED_output { v1 v2 } {}
With this procedure, it is easy to count the number of times which we use spindle_marker or if this info exist
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Re: Spindle Marker
Thanks, but I am looking for something in Post Builder to let me know when or if the Spindle Marker has been used in an operation.
Senior Aerospace
Re: Spindle Marker
HI
This Marker is using the UDE, if you add "spindle marker" in operation UDE than next add the "insert" UDE and put the M code than genrate the nc code and you can see the after spindle ON (M03) next line for you M code.
Re: Spindle Marker
I have several hundred files that already have the spindle marker in them.  I am looking for something that will identify if a Spindle Marker has already been used.
Senior Aerospace
Re: Spindle Marker
I'm not sure if the post can report this.
Your best bet may be a journal to process all the operations in a part , go thru the "start" events, and look to see if it is there.
I have some code that I stole from GTAC (ugsolutions database? - although I can't seem to find it anymore).  Should get you close (try combining w/ some of Marks code to process all operations in a part?)
' From GTAC / UGanswer
' stolen on 26-Nov-2012
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.Annotations
Imports NXOpen.UF
Imports NXOpen.CAM
Imports NXOpen.Utilities
Public Class Program
    ' class members
    Private Shared theSession As Session
    Private Shared theUI As UI
    Private Shared theUfSession As UFSession
    Private Shared lw As ListingWindow
    Public Shared Function Main(ByVal args As String()) As Integer
        theSession = Session.GetSession()
		Dim workPart As Part = theSession.Parts.Work
        theUI = UI.GetUI()
        theUfSession = UFSession.GetUFSession()
        lw = theSession.ListingWindow
        lw.Open()
' DOES NOT WORK IN ONT		Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
'		lw.WriteLine("Selected Objects: " & numsel.ToString())
		Dim num_nodes As Integer = 0
		Dim nodes As Tag()
		theUfSession.UiOnt.AskSelectedNodes(num_nodes, nodes)
        lw.WriteLine(" Found " & num_nodes & " selected nodes - only doing first selected object...")
		If num_nodes <= 0 Then
			lw.WriteLine("No CAM node selected...exit")
			Return (1)
		End If
		Dim camObject As NXObject = NXObjectManager.Get(nodes(0))
		lw.WriteLine(" Found type = " & camObject.GetType().ToString() )
		Dim params1(0) As CAM.CAMObject
		params1(0) = CType(camObject, CAM.CAMObject)
        Try
			Dim objectsUdeSet1 As CAM.ObjectsUdeSet
			objectsUdeSet1 = workPart.CAMSetup.CreateObjectsUdeSet(params1, CAM.CAMSetup.Ude.Start)
            lw.WriteLine(" Found " & objectsUdeSet1.UdeSet.UdeList().Length() & " Start UDEs...")
			Dim UDE_Array as Ude() = objectsUdeSet1.UdeSet.UdeList.GetContents()
            'lw.WriteLine("     UDEArray size = " & UDE_Array.Length())
            For i As Integer = 0 To UDE_Array.Length() - 1
				'lw.WriteLine("     UDEArray item = " & i)
                lw.WriteLine(vbLf & "    UDE: " & UDE_Array(i).UdeName())
                lw.WriteLine( "    TYPE: " & UDE_Array(i).GetType().ToString())
                Dim num_params As Integer  = UDE_Array(i).NumberOfParameters()
                lw.WriteLine( "    PARAM COUNT: " & num_params.ToString())
                For j As Integer = 0 To num_params - 1
                    Dim thisParam As UdeParameter = UDE_Array(i).GetParameter(j)
					lw.WriteLine( "        PARAM " & j.ToString() & " NAME: " & thisParam.NameOfParameter)
					lw.WriteLine( "        PARAM " & j.ToString() & " ACTI: " & thisParam.ParameterActive.ToString())
					lw.WriteLine( "        PARAM " & j.ToString() & " OPTN: " & thisParam.ParameterOptional.ToString())
					lw.WriteLine( "        PARAM " & j.ToString() & " TYPE: " & thisParam.GetType().ToString())
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE INT: " & thisParam.IntegerValue.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an int")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE BOOL: " & thisParam.BooleanValue.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an boolean")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE DBL: " & thisParam.DoubleValue.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an double")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE OPT: " & thisParam.OptionText.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an option")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE STR: " & thisParam.StringText.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an string")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE PNT: " & thisParam.Point.Coordinates.X.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an point")
					End Try
					Try
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE VEC: " & thisParam.Vector.ToString())
					Catch
						lw.WriteLine( "        PARAM " & j.ToString() & " VALUE not an vector")
					End Try
                Next
            Next
        Catch ex As NXOpen.NXException
            'try
            UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.[Error], ex.Message)
        End Try
        Try
			objectsUdeSet1 = workPart.CAMSetup.CreateObjectsUdeSet(params1, CAM.CAMSetup.Ude.End)
            lw.WriteLine(vbLf & " Found " & objectsUdeSet1.UdeSet.UdeList().Length() & " End UDEs...")
			' Re-add stuff
            Next
            'try
        End Try
		' ignore groups & other "non-operations"
		' only operations can have non-start and non-end UDEs
		Try
			' Filter groups
			Dim answer As Boolean
			' If the object is not an operation then leave without doing anything more
			theUfSession.Ncgroup.IsGroup(params1(0).Tag(), answer)
			If answer = True Then
				lw.WriteLine("Selected object is a group...")
				Return 0
			End If
			' filter out other non-operations
			If NOT TypeOf camObject Is CAM.Operation Then
				lw.WriteLine("Selected object is a not an operation...")
				Return 0
			End If
            'try
        End Try
        Try
			' Filter JUST *control operations
			Dim operationType As Integer
			Dim operationSubtype As Integer
			'Get the type and subtype of the operation
			theUFSession.Obj.AskTypeAndSubtype(params1(0).Tag(), operationType, operationSubtype)
			'lw.WriteLine(" Found type = " & operationType & " subtype = " & operationSubtype)
			' type 100 subtype 1100 = mill/drill control
			' type 100 subtype 1200 = lathe control
			' type 100 subtype 1300 = Wire EDM control
			' TODO: What about machine control sub-ops in turning teach mode operations?
			' TODO: What about generic motion sub-ops?
			Dim udeSet1 As CAM.UdeSet
			If operationSubtype = 1100 Then
				Dim operationBuilder As CAM.MillMachineControlBuilder
				operationBuilder = workPart.CamSetup.CAMOperationCollection.CreateMillMachineControlBuilder(camObject)
				udeSet1 = operationBuilder.UdeSet
			ElseIf operationSubtype = 1200 Then
				Dim operationBuilder As CAM.LatheMachineControlBuilder
				operationBuilder = workPart.CamSetup.CAMOperationCollection.CreateLatheMachineControlBuilder(camObject)
			ElseIf operationSubtype = 1300 Then
				Dim operationBuilder As CAM.WedmMachineControlBuilder
				operationBuilder = workPart.CamSetup.CAMOperationCollection.CreateWedmMachineControlBuilder(camObject)
			Else
				Return 0
			End If
				lw.WriteLine(vbLf & " Found " & udeSet1.UdeList().Length() & " Control UDEs...")
				Dim UDE_Array as Ude() = udeSet1.UdeList.GetContents()
				Next
            'try
        End Try
        Return 0
    End Function
    Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
        Return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately)
    End Function
End Class
Re: Spindle Marker
The post proc "MOM_spindle_rpm" is called when there is a Spindle Marker UDE although it is also called with an Extra Spindle On  and maybe more events. It might be helpful though to throw an alert when posting to check that operation.
HTH Eric
Re: Spindle Marker
Eric,
Thanks this may be a simpler solution.
"Sometimes you can't see the forest for the trees "
Senior Aerospace
Re: Spindle Marker
Note (IIRC) MOM_spindle_rpm is called anywhere the spindle is turned on?
So you may get a lot of "false positives"
If you want to get REALLY tricky, you could menuscript a /PRE action on the postprocess button.  Then use a journal (I think) to check for them & abort posting (or warn the user or whatever) if they exist.
Another option would be to run a journal against all your parts & report which ones have this issue.  Then go thru & fix them, and not have to worry about them anymore.
Re: Spindle Marker
In my testing MOM_spindle_rpm was not called from an operation that has no start events but maybe I missed something. I just added a dummy text comment to see if it was output to the posted code.
Eric
