Do you mean
Reply
Solved! Go to solution
Streamline operations in nx11vs Solidcam
Hi all,
I need help with programming milling radius marked in red obr1. by Streamline. For machining it is necessary to use a ball mill average 4. I tried various settings in the streamline, but unfortunately the track are still bad obr3. I enclose a model and pictures. Railways should look like Figure 5, which are generated in SolidCAM.
I'll be glad for any help with setting pathways that are the same as the SolidCAM.
Thank you very much
Re: Streamline operations in nx11vs Solidcam
I try it with contour surface area and it gives better result.
NX 11.0.2.7 MP1 / CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
Solution
Solution
Accepted by MarkRief (VIP)
‎01-19-2017 07:00 PM
I also try with streamline ı hope it helps.
www.caniksoft.com
Thank you so much. That's exactly it
I'm very grateful.
Have a beautiful day
Vrey good for this help !
How was this accomplished? I tried Surface Area and get a grid error.
-Bill
Organization, an essential part of Productivity !
Production: NX10.0.3 MP13, VERICUT 8.0
Development: VB.NET, Tcl/Tk Testing: NX11.0, iMachining 2.0, Adaptive Roughing
-Bill
Use the Streamline drive method, not Surface Area.
Mark Rief
Retired Siemens
