T31 Z-10 CSE SIMULATION
Hello!
For SWISS-type machine I need simulate nc-programm with line:
T31Z-10.
Real CNC set active T31, read tool compensation and after it make a Z-10 motion.
CSE - first of all make a Z-motion and after it start my subroutine for tool change and tool compensation.
How I can do T31 action first, and after it - Z-motion?
Thanks!
Re: T31 Z-10 CSE SIMULATION
I understand you need first set the tool length compensation and move the Z value including that correction.
Here one Idea how to solve it:
catch’ the Z meta code together with the M6
use the value to set a subprogram parameter (AddSubProgParam)
update the tool change subprogram to define a parameter
use the value of the Z parameter to do the motion at the end of the tool change
Hope it helps
Thomas Schulz
Siemens PLM
Thank you, Thomas!
I havenot M6 code, no need for this type machine. But, I found a same solution -
I check isDefined(Z), and set some #VAR to Z value. And add last line to ToolChange sub Z[#VAR]
